 Topic: 2t oil in gearbox?
Andy » Sun May 16, 2004 8:09 pm
This is not exactly a common problem, but it's not unheard of either! Rolling Eyes
It will indeed have been caused by the oil seal under the injector pump "moving".
The seal itself is not actually available from Honda and is a strange size, but it is apparently a size used on a number of jet-ski/wave runner type motors, so take the pump along to a good bearing/seal specialist or water-sports dealer, and they should be able to match it up for you.
A thin smear of silicone/RTV on the outside of the seal before you press it back in should hold it in place securely.
As a word of caution, and easy to say with hindsight, I make sure the oil tank on my MC21 is ALWAYS topped to the brim - even topping it back up after a little jaunt to the beach and back. Therefore, if the level when I come to the bike is EVER lower than fully topped up, I would know it needed investigation before riding!
