scottvor wrote:
At some point I had one or at least it was a port map of NF5 RS250 which I believe is very close. Let me root around and see if I still have something.
Try looking in the HRC section!
There is no specific HRC TT-F3 port map. F3 barrels had the same timing as stock barrels. Be aware it's also very easy to ruin stock porting and end up with a lightswitch, especially if you start messing with the internal shape of the transfer ports!
