 Topic: MC21 SE/SP fork internals, bottom got loose
tomzilla808
tomzilla808 » Wed Apr 12, 2017 6:30 am
in the second photo you can see the snap ring that will keep the compression damper shim stack from coming out the bottom. There is nothing above it to keep it stationary as once everything is bolted together it will not move. This is normal. If you wish you could remove the snap ring to clean the compression shim stack as well as push the rod out to reveal the rebound valve stack to likewise clean and inspect.
