 Topic: MC18 R2J Project
waynevanrooyen
Crank Case Split
waynevanrooyen » Mon Jun 19, 2017 5:09 am
So Troy split the cranck case and low and behold the rust in tank may have done its damage it intended to do.
Clutch still looks good, but the bearings are shot, so much side to side play, apart from the fact that wrong bearing was used also. Now in the desperate hens teeth search for R2J crank bearings.
