Set up well, I don't think you'll regret going with the NSR.
As I already mentioned, there's no reason for it not to make over 65rwhp, and with fresh suspension and a set of HRC spec rear shock link plates, the handling should be more than sharp enough for most. The link plates are a must though, to raise the rear ride height and stiffen things up, as the geometry is quite lazy in stock trim.
