 Topic: NF5
paul g » Thu Feb 21, 2019 10:36 pm
Next up was the swinging arm. This was corroded worse than the frame plus it had the inevitable crash damage with the paddock stand bobbins ground away and a nasty dent caused by the rear set being pushed in to it.
20181109_142130 by Paul Goat, on Flickr
20181109_155115 by Paul Goat, on Flickr
This called for a little more ingenuity and after a bit of thinking I hatched a cunning plan Idea I drilled a hole in the dent and drilled and tapped a piece of mild steel the same width as the extrusion section.
20181109_150051 by Paul Goat, on Flickr
20181109_150324 by Paul Goat, on Flickr
I then annealed the dented area and used part of my blind bearing puller kit to pull the dent out. Simples Very Happy
20181114_132137 by Paul Goat, on Flickr
20181109_154513 by Paul Goat, on Flickr
It then went for welding and vapour blasting.
20181122_151610 by Paul Goat, on Flickr
20181122_151618 by Paul Goat, on Flickr
Cleaned the welds up and a good going over with scotchbrite and the result was better than I had hoped for.
20181124_132223 by Paul Goat, on Flickr
20181124_132231 by Paul Goat, on Flickr
20181124_132238 by Paul Goat, on Flickr
20181122_151552 by Paul Goat, on Flickr
