 Topic: B piston on B cylinder
manuryno
manuryno » Fri May 17, 2019 12:35 pm
Hi everyone!
Bring this topic back to try to find out which in the biggest piston available for my MC 21.
The manual says thereīre three sizes: B - 53.966~53.969mm
No# - 53.962~53.965mm
C - 53.958~53.961mm
I donīt know if this is right, as itīs the first time Iīve seen this system, usually the A piston is always the smallest.
The other strange thing is that Iīve found these pistons in the parts list: B piston 13102-KV3-830
No# piston 13103-KV3-830
D piston 13104-KV3-830
Does anyone know the reason of this difference and/or the real sizes of the pistons in the parts list? I need to fit the biggest ones as my cylinders are close to the wear limit.
Thanks a lot!!!
Two Stroke Power
