 Topic: Oil leaking at RC valve ?
Max
Max » Thu Feb 13, 2020 8:34 pm
Andy wrote:It's difficult to come up with ideas when you can't see for yourself what's going on. I'm just trying to think of possible scenarios. At the end of the day, there's only two places it can originate from. The 2T reservoir(s) or the transmission... or a family member/friend with a warped sense of humour! Laughing
I would've thought it's unlikely that holding the 2T pump pulley wide open for a minute on idle would be enough to create a pool of oil under the bike. Best plan is probably to get in there with carb/brake cleaner and thoroughly clean away any oil residue and start it back up to see if you can trace the culprit.
Hi Andy
I thought I would update you on this now that I have spent some more time on the bike.
I found a snapped exhaust header stud which is causing the oil wetting around the RC valve and there is definitely a leak on the oil pump somewhere (not investigated yet as working on the barrel etc)
So a combination of two issues making the right side of the engine soggy and miserable!
Thanks for your input and effort 👍
