 Topic: Re plating, what are the chances?
Andy » Tue Feb 25, 2020 10:06 pm
Max wrote:
Andy: can I ask why you would replace the rings at least?
Well why wouldn't you, while it's all apart? Confused
Max wrote:
Regarding rings, I see a D shape in the top ring groove on the piston, which I assume is the mark for aligning the ring gap....should I see similar on the bottom expander ring groove?
No ring expander on the MC21. (It was only ever a thing on the MC16, and long discontinued.)
There's a peg in each groove for ring alignment. Note that the grooves are different shapes when you refit the rings. And yes, we have seen a flat ring jammed into the keystone groove before! Shocked
