 Topic: Oil leaking at RC valve ?
Andy » Wed Mar 11, 2020 2:03 pm
If you want clear oil lines, I'd maybe try to get some from the local RC car model shop. Never done it myself, as I've never encountered a problem with the OEM lines, but that's probably where I'd start.
You could always flush the OEM lines with some carb cleaner to check there are no blockages or restrictions, and then even prime them with 2T if you're so inclined.
