 Topic: nsr250se mc21 carb need some input/help
innovativems
innovativems » Mon Apr 13, 2020 12:42 pm
Andy wrote:It sounds like one of the emulsion tubes is an HRC item. Is it about 2mm longer on the larger end [where the main jet screws in]?
This diagram should help identify which carb is which...
Sorry it's a bit small, but should be clear enough for identification purposes.
You are spot on, one is 2mm longer then the other.
