 Topic: mc21 se 1992 fork lowers.
Max
Max » Fri May 01, 2020 6:16 pm
paul g wrote:As Tom said I have restored a few pairs of forks, I have them vapour blasted first and then use a scotchbrite flapper wheel.
If you look at a pair of original fork bottoms they have a grained finish although this doesnt run all the way to the brake lugs and other protrusions that are hard to polish, I masked out the appropiate areas and grained the forks with a scotch brite flapper wheel in a drill then laquered the fork leg.
The last pair I had clear powder coated which should be a bit more durable than laquer.
Hi Paul
Can you advise what you used to strip back the lacquer...I have a feeling that today's PC version of Nitromors won't be man enough...
EDIT: then as I posted the question I read that you had them vapour blasted first, Doh!
