 Topic: First day getting mc18, bike doesn't start...
Max
Max » Fri May 29, 2020 7:07 pm
Start with the easy stuff... fuel, air and spark.
Hopefully the spark plugs will give you an indication of whats going on...if I had to place a bet I would put money on it being fuel starvation.
So... tank breather, fuel filter on the tap and carburettor bank, open up the carb bowls and inspect.
If I read right the bike seems to run better with the choke applied, so maybe fuel.
To add an image you need to resize I go just below 230K by reducing the dimensions, then simply click add attachment before you submit.
Good Luck!
