Zeus wrote:Check that the needles haven’t been adjusted and that they are at the standard setting, also check that the choke plunger at the carb actually is moving when you pull the cable. I’ve had them feel like they are moving but they’re not!
I am being lazy but where will I find the needle height and float height info on here? Cheers
