 Topic: Exxhaust Seals
tleighbell
Exxhaust Seals
tleighbell » Thu Sep 24, 2020 12:55 pm
Just bought exhaust to cylinder seals Part # 18293 KV3 004 for an MC28 engine. They seem very thick compared to the seals that were on there. they are the same thickness as the flange so i end up with a butt joint and fhe flange does not fit into the opening.
Measurements of the 2 different seals are:
ID OD Thickness
Installed 44.1 mm 55.5 2
18923KV3004 43.5 59.4 6 ( the steel part only, assuming the copper parts will crush flat)
Am I ok with those seals? I have no idea of the ones installed were correct.
