 Topic: Cannot get to run correctly
Andy » Mon Oct 04, 2021 6:22 pm
Admin: Moved to NSR250 Discussion for greater visibility.
Welcome to NSR-WORLD, "bigoperation"! Smile
If you click the Member's Content link at the top of the page, you will be able to see our [translated] English Service Manual, which has a number of trouble shooters to try and help diagnose potential issues. The main body of the manual (the first 300 pages) cover the entirety of the MC16.
Also, in the Workshop section of the Main Site, is a generic electrical fault finding guide by Electrex USA, which many have found useful in the past.
It's always incredibly difficult to diagnose a problem online, and in almost 30 years of tinkering with NSRs, I've seen dozens of reasons why this can happen. I think you can take some consolation that when you swapped out one of the CDIs it ran cleanly, albeit temporarily. That would give me hope that it's nothing too critical.
I did note from the sound in first video that the bike is fitted with aftermarket chambers. Normally the first thing I say in these kinds of situations is "put everything back to stock", but realise this is almost certainly impossible where you are. Just be aware that there weren't a huge amount of aftermarket pipes for the MC16 back in the day, and if they are "local" chambers, or even adapted MC18 items, it could drastically effect performance. I've seen copies of TYGA chambers from both Indonesia and Malaysia, that were horrendous! The people who are producing the copies clearly don't understand just how critical every dimension is.
Lesviffer750 wrote:
Check all the plumbing around the carburrettors, ie air solenoids etc, i have seen this problem before, ie fine on stand, but wouldnt pull, if i remember correctly, it was johnymac who had this problem and it was related to the air correction system, i think it was either a pipe blanked off, which shouldnt have been, or vica versa, good luck with it.
The MC16 doesn't have the air correction wizardry of the later models, Les, it's rather simple by comparison. However, I would definitely ensure any hoses/breather tubes are clear and in good condition. Also the fuel tank breather.
I would be more inclined to use the OEM carb internals than pattern parts. I don't recall ever seeing an aftermarket carb kit for the MC16, and given that the needles are different in every single iteration of NSR, if the kit was meant for an MC21, or even 1988 MC18, they're likely to perform wildly different to the correct OEM 2QY/2QZ items, if at all. Try and keep everything as close as stock as possible, while trying to troubleshoot.
I look forwards to seeing more of your MC16 in due course. It looks great in "NSR-WORLD" colours! 😄😄
