Andy wrote:kangranwang wrote:Andy wrote:No, I mean with your current repaired part. I wouldn't trust any kind of "epoxied" repair on the cooling system. I've seen leaks destroy a motor faster than you can grab the clutch.
I see. But my water outlet has a big leak and if I don't replace it then the bike cannot work. Do I have any other way around? I've also ordered a fan with a switch I wish that would help.
I'd honestly just wait for the new (used) part to arrive. Epoxy is notorious for failing in cooling system repairs. The hot coolant seeps between the base material and the epoxy and the pressure blows it out. You may be lucky, but it you're not, at best you'll likely seize a piston, but worse case scenario is a totalled motor and you laying in a ditch at the side of the road.
I speak from experience.
Thanks Andy! The part would come in a month because it's from the UK and I live in North America, but I guess I would wait then:)
