 Topic: MC21 Rebuild
Andy » Tue Jun 28, 2022 5:31 pm
Be careful when you insert the cassette back into place.
There's a small spring that needs to be hooked back inside the cavity that can be easily overlooked, and get trapped between the crankcase and bearing holder. If you try and torque down the screws without hooking the spring into place, you'll crack the bearing holder.
