I had COVID for my Christmas present! so going to delay celebrations for a while; bonus it gave me time to finish the WEBIKE list as far as I am going with it, I even found the elusive Main Bearing set and Seals for the 88 NSR250 which I had heard a lot about LOL.
Anyway hope you had a good Christmas Day and wish you and all who read this all the very best for 2023.
Phil
OIL SEALS 1
Water Pump Seal High Performance Oil Seal 1
Product E4-21011 1
Engine Set/wet Clutch High Performance Low Friction Oil Seal 1
Product E5-21045 1
Engine Set / Dry Clutch High Performance Low Friction Oil Seal 1
Product E5-2104 1
Perfect Set / Dry Clutch High Performance / Low Friction Oil Seal 2
Product E5-21046 2
Perfect Set / Wet Clutch High Performance/low Friction Oil Seal 2
Product E5-21047 2
Seal Low Friction Driven Gear /Dry Clutch Housing/ Oil Seal 2
Product E5-21043 2
DMR-JAPAN [Pepex Seal] High Durability / Low Friction Oil Seal 4
Product E5-21044 4
Seal High Performance Kick Spindle Oil Seal 5
Product E3-21002 5
Seal High Performance /Dry Clutch/ Oil Seal 5
Product E5-21042 5
Seal High Performance RC Valve Oil Seal 6
Product E1-21005 6
Seal High Performance Clutch Release Lever Oil Seal 6
Product E8-21001 6
Seal High Performance Gear Shift Spindle Oil Seal 6
Product E11-21004 6
Seal Low Friction Rear Wheel Oil Seal 6
Product F10-21003 6
Seal Low Friction Front Wheel Oil Seal 7
Product F10-21002 7
Seal Low Friction Gearbox Countershaft Oil Seal 7
Product E10-21001 7
FORK SEALS 8
TECNIUM ??Fork?? Oil Seals w/out Dust Cover 8
Product 1043916 Fitment HONDA 8
TECNIUM Blue Label Fork Oil Seal & Dust Cover Kit 8
Product 1042184 8
SKF Front Fork Seal Kit 9
Product KITG-41S 9
RC VALVE PULLEYS, CABLES & REED VALVES 11
DMR-JAPAN Reed Valve Spacer Dongabacho 11
Product E13-21035 11
DMR-JAPAN Wide Pulley Type2 (RC Valve Pulley) 12
Product F27-21002 12
T2 Racing RC Valve Titanium Works Pulley 13
Product T2-Ti-RC 13
T2 Racing RC Valves and Cables 14
Product T2-N25-W-BRC 14
T2 Racing Factory Pulley Kit [Racers Series] 15
Product T2RACERS-NE-RC 15
OTHER CABLES 17
T2 Racing Accelerator Wire Kit 17
T2-N25-W-AW21 17
T2 Racing Blue Choke Wire 17
Product T2-N25-W-BCH28 17
ALCAN hands Clutch Wire 18
Product JB141C00 18
T2 Racing Clutch Cable For Dry Type 18
T2-N25-W-BCC-D 18
T2 Racing Speedometer Cable Blue 19
T2-N25-W-BSM 19
CLUTCH 20
DMR-JAPAN Ultra Light Aluminium Driven Gear Inner (Karukushima Senka) 20
Product E5-21001 20
DMR-JAPAN HI Mu Disc 5-Piece Reinforced Clutch 21
Product E5-21002 21
DMR-JAPAN Needle Bearing Conversion Kit 22
Product E5-21003 22
DMR-JAPAN HI Mu Disc 5-Piece Reinforced Clutch (Disc Plate Set) 23
Product E5-21021 23
DMR-JAPAN 6-Piece Clutch Kit 24
Product E5-21022 24
DMR-JAPAN 6-Piece Clutch Kit 25
Product E5-21023 25
DMR-JAPAN Clutch Plate 25
Product E5-21024 25
DMR-JAPAN Clutch Lifter Piece 26
Product E5-21026 26
DMR-JAPAN Clutch Lifter Rod 26
Product E5-21027 26
DMR-JAPAN Clutch Oh Kit 27
Product E5-21028 27
DMR-JAPAN (Dry & Wet) Reinforced Clutch Spring 27
Product E5-21029 27
DMR-JAPAN Spacer 28
Product E5-21030 28
DMR-JAPAN Bearing Collar 28
Product E5-21031 28
DMR-JAPAN Clutch Outer Collar (Clutch Outer Guide) 29
Product E5-21032 29
DMR-JAPAN Ultra Light Pressure Plate Kit 30
Product E5-21033 30
DMR-JAPAN Lightweight Clutch Kit Type1 31
Product E5-21034 31
DMR-JAPAN Lightweight Clutch Kit Type2 32
Product E5-21035 32
DMR-JAPAN Ultra Light Pressure Plate Kit 33
Product E5-21048 33
DMR-JAPAN Lightweight Clutch Kit 34
Product E5-21049 34
DMR-JAPAN Lightweight Clutch Plate 34
Product E5-21050 34
DMR-JAPAN Clutch Plate 35
Product E5-21052 35
T2 Racing Clutch Release Value Set [For Dry Engines] 35
Part Number T2-Ti-CRSTKS-D-BLBL 35
T2 Racing Titanium Clutch Release 36
Product T2-Ti-CRS 36
T2 Racing Clutch Release Value Set [For Wet Engines] 37
Product T2-Ti-CRSTKS-W-BLBL 37
DMR-JAPAN Orbital Wheels [Replacement] 37
Product GP015 37
DMR-JAPAN Thrust Needle Bearing [Replacement] 38
Product GP016 38
T2 Racing Wet Type Clutch Kit 38
Product T2-N25-WCK 38
CARBURETTOR 39
DMR-JAPAN Lightweight Machined Aluminium Top Cap 39
Product E13-21006 39
DMR-JAPAN Machined Aluminium Fuel Joint Pipe 40
Product E13-21014 40
DMR-JAPAN Number 0, Power Jet, Mecra Jet. 41
Product E13-21028 41
DMR-JAPAN Honda Type Carburettor Drain Bolt (drain Screw) 41
Product E13-21033 41
DMR-JAPAN Float Valve Seat Set (with Filter) 42
Product E14-18001 42
POSH 6 Oversize Main Jet Set 43
Product 711613-10 43
T2 Racing Float Valve 44
Product KY-N25-008 44
T2 Racing Float Valve Seat 45
Product KY-N25-007 45
KEYSTER Carburettor Fuel Adjustment Kit 46
Product FH-5206N 46
KEYSTER Carburetor Fuel Tuning Kit 47
Product FH-5203NL 47
KEYSTER Fuel Adjustment Kit & Throttle Valve Guide Gasket 48
Product FH-5262NLP 48
KEYSTER Burning Kit & Throttle Valve Guide Gasket [for 1 Cylinder] 49
Product FH-5203NLP 49
KEYSTER Carburetor Fuel Adjustment Kit 50
Product FH-5105NR 50
KEYSTER Carburettor Fuel Tuning Kit 52
Product FH-5106NL 52
KEYSTER Carburetor Fuel Adjustment Kit 53
Product FH-5262NR 53
COOLING SYSTEM 54
DMR-JAPAN Clutch Cover Gasket Set 54
Product E3-21001 54
DMR-JAPAN Bearings For Water Pumps 54
Product E4-21001 54
DMR-JAPAN Mechanical Seal Oh Kit 55
Product E4-21002 55
DMR-JAPAN Racing Type (Mechanical Seal-less Kit) Water Pump Gear 56
Product E4-21003 56
DMR-JAPAN Water Pump Gear (Standard Type) 57
Product E4-21004 57
DMR-JAPAN Water Pump Gear Overhaul Kit (Stock Type) 58
Product E4-21005 58
DMR-JAPAN Street Type Water Pump Gear 59
Product E4-21006 59
DMR-JAPAN Water Pump Gear Gasket Set (Stock Type) 61
Product E4-21008 61
DMR-JAPAN Racing Type (Mechanical Less Kit) Water Pump Gear 62
Product E4-28001 62
DMR-JAPAN Water Pump Gear Gasket Set (Stock Type) 63
Product E4-28002 63
DMR-JAPAN Street Type Water Pump Gear 64
Product E4-28003 64
DMR-JAPAN Water Pump Gear Overhaul Kit (Standard Type) 66
Product E4-28005 66
DMR-JAPAN Water Pump Gear (Standard Type) 67
Product E4-28006 67
DMR-JAPAN Low-Temp Thermostat 68
Product E4-21010 68
T2 Racing Destra Water Pump Cover 69
Product NE-N25-WPC-RD 69
TYGA PERFORMANCE Water Pump Shaft/Gear 69
Product TPER-5003 69
TYGA PERFORMANCE Water Pump Shaft / Gear 70
Product TPER-5004 70
TYGA PERFORMANCE Water Pump Shaft 70
Product TPER-5002 70
T2 Racing Water Pump Gear RESIN [T2 Racing VERTEX Series] 71
Product NE-N25-WP1821R 71
T2 Racing Silicon Radiator Hose [Full Set] 72
Product T2-N25-RH18-S 72
T2 Racing 1-Layer Radiator [MC21 / 28] 73
Product T2-N25-1R-2128 73
T2 Racing Factory Radiator [Racers Series] 74
T2RACERS-2R-N25 74
ENGINE & ASSOCIATED PARTS 75
DMR-JAPAN Packing Set Above Waist 75
Product E1-21001 75
DMR-JAPAN Crank OH Kit A 76
Product E9-21005 76
T2 Racing Crank Centre Seal 77
Product T2-N25-88C 77
T2 Racing Crank Right Side Oil Seal 77
Product T2-N25-88R Fitment HONDA 77
T2 Racing Crank Overhaul Kit 78
Product T2-N25-88OHK 78
DMR-JAPAN Oil Seals For Oil Pumps 79
Product E7-21001 79
DMR-JAPAN Oil Pump Seal 80
Product E7-21002 80
DMR-JAPAN O-ring Set For Inside Of Oil Pump 81
Product E7-21003 81
DMR-JAPAN Special Reed Valve Kit 81
Product E7-21004 81
PROTEC GPS-01 Gear Position Sensor 82
Product 11609 82
T2 Racing Oil Pump Seal Kit 83
Product T2-N25-OPSK-R 83
T2 Racing Super Lightweight Flywheel 84
Product NE-N25-FW3 84
T2 Racing Engine Mount Bolt Set 85
Product T2-Ti-set-023 85
ELECTRICAL 86
Main Harness for MC18 (8
Product F28-18001 86
6V MONKEY/GORILLA Main Harness for MC21 87
Product F28-21002 87
DMR-JAPAN RC Valve Cable Adjustment Harness Hi Ni Susumukun 88
Product TL001 88
DMR-JAPAN Regulator Conversion Kit 89
Product F17-18001 89
DMR-JAPAN 16P Female Coupler Set for PGM 90
Product F28-21008 90
DMR-JAPAN OEM Replacement Handlebar Switch 90
Product F3-18001 91
DMR-JAPAN OEM Replacement Handlebar Switch 92
Product F3-18002 92
Product F3-21001 93
KITACO Headlight ON/OFF Switch Kit 94
Product 755-1000200 94
ANCILLIARY 95
TYGA PERFORMANCE Fairing Set MC18 95
Product BPFS-0158 95
T2 Racing RSW Type Front Fender 96
Product T2-FF-RS-CC 96
K-PIT Lever Right Side MC18/21/28 97
Product 70-525-61041 97
NISSIN [Stock Lever] Brake Master Cylinder Kit MC18 88-89 97
Product 61743 97
T2 Racing Kevlar Carbon Stainless Steel Silencer [insert] 98
Product T2-CB-S-030 98
T2 Racing Seat Rubber Type 2 99
T2-SR02 99
OHLINS Rear Suspension 100
Product HO206 100
TOOLS 101
Primary Gear Holder (Crankshaft End in Clutch Housing) 101
Product TL006 101
DMR-JAPAN RC Valve Puller (Bolt Type) 101
Product TL004 101
DMR-JAPAN RC Valve Puller (Sliding Hammer Type) 102
Product TL003 102
DMR-JAPAN Mechanical Seal Installer 102
Product TL007 102
DMR-JAPAN Rear Sprocket Flange Puller 103
Product TL005 103
