Ken
Eastern Ontario
Andy wrote:Your best bet, almost certainly, is going to be Yahoo! Auctions or proxy company such as Jauce or Buyee, although of course, it's worth putting an advert in the Classifieds section here just in case.
I expect you will need to buy a complete set of carbs and rob the TPS, but you do see them come up on their own from time-to-time.
NOTE: If you buy a TPS on it's own, ensure the little white joint (that fits between the slide lifter shaft and the TPS) is present.
