 Topic: Can you use early MC18 side fairings with an MC16 nose cone?
Rothmans_SPud » Fri Mar 28, 2025 6:06 pm
Forgot I had these on my phone but will do a better comparison over the weekend
The only difference I can see is this cut out – clearly the MC16 won’t fit an 18 as the water ducting is too small but going the other way 18 on a 16 should be fine
I will also check the screw holes for frame mounts
MC18 right hand panel
IMG_5856
MC16 right hand panel
IMG_5855
