Hi there,
I have been missing for a while.  Sorry guys but i had a lot of things to think the last few months so i am back again.  Lets talk about the problem I have!
3 months ago my bike started fouling the front spark plug.  I thought carburators!!!  So i pulled them out and i cleaned everything that had to do with the carburators, i set the float height and tested them.  Everything ok.  Placed them back, i changed the spark plugs and went for a ride.  Same things again!!!  I have checked my carbs 5 times.  So I went for a crank rebuild.The mid bearing was at its last days!!!  Rebuilt the crank and the engine and went for a ride.  Same thing again.  The front cylinder misfires at idle and a lot of fume comes out of the exhaust, this is unburned fuel. After 3 or 4k rpm the bike works good.  Also when i try to hold the throttle between 2 to 4k rpm the right carb spills out fuel.  Guys I've checked everything except the electrics and i have completely gone crazy.  Please any advice would be welcomed.
Thanx in advance guys!!!
