fstnsr wrote:what u can do is plug up one end then pressurize the other and heat the dents with a tourch...biatchy wrote:what could i use to pressurise it?fstnsr wrote:compressed air or even if u block both ends as it heats the air shold expand and create a preasure.
Using compresed air is extremely dangerous, as the pipe can explode. Any pipe builder worth his salt would most likely use hydraulic pressure - probably oil - but it's not a job to be undertaken lightly.
Send a PM to "martin77" and ask him - he'll be building our race pipes soon.
Like a few of the guys have said though, if they are stock pipes then I wouldn't worry too much as it's probably only the outer "skin" that's dented anyway.
