 Topic: Maintaining an nsr
fontyyy » Tue Oct 04, 2005 8:28 pm
Matt@TYGA wrote: check pads
This is a good one, when I got my '28 it had some nasty squared of 120/160 tyres on, a buddy of mine has a mate who races 125's so I got some 110/150 D208gp's cheap, took my wheels of and....
3 front brake pads fell out, the backing plate stayed there but the material just fell onto the floor and broke!
Then I took the back wheel off to see the material on one side 2/3rds of the way out of the caliper, once again backing plate still held in.
I nearly needed a full set of discs to go with the 2 pistons, 2 replates, 1 repair, 1 head, 1 HRC jet kit, 1 air filter, 1 chain, 1 front sprocket, 1 gear selector shaft, 1 clutch, 1 throttle body and all the ancillaries that are needed to fit that little lot that it had needed already.
You may want to choose a little more carefully than I did Idea
