Maxim, I understand totally, what is the oil pump maximum? surley afetr a dyno run the mixture will be looked at? ill ask the question, I only have 1 problem, if i need a blanking kit for the oil pump where can i get one quickly....
Nigle what did mick say about your mixture? afterall im have god dam as near same set up as you, (or will have) i even just ordered the head conversion which mick said you had as well. (copy cat copy cat)
fingers crossed it all goes well, Nigle ill see ya at donnington, Maxim did you book in?
