I'd be very interested to hear what the problem is. Mine is starting to experience the same hard starting problems. Runs fine after starting but has to be kicked 20-25 times to get it going. I did a compression check this last spring and got around 120psi on both cylinders. It started fine then. Guess I'll start by checking my compression too.
