Matt i think you have answered my question thanks, there is back and forth on the outer basket once bolted down on the big gear (with case off its the big gear that connects to the small gear on the end of the crank) LOL that the clutch basket mounts too, its on 2 roller bearings with a 2 part coller, and yes when i did a mock install of the iner basket NO movement on the iner basket, it is the gear movingback and forth on the shaft not the shaft itsefl Cheers! it dose look about 3mm thou, IS THAT ABOUT RIGHT? but everything on that shaft went back in, INER COLLER, 2 bearings, O ring on shaft Outer coller etc (which is the bit the iner basket tightens up agaisnt i guess), Cool! i havent lost a bit, LOL just spent an hour going throu the parts section starting to wonder if honda mised a bit LOL nearly done then!
By the way anyone reading this, the wet clutch and gear box was a pieace of piss, when i started all this i was real worried but you can almost throw the wet clutch and box at the bike and itll land in the right place, good to know if you ever want to take it apart for repair, clean or like me to swap it for a dry clucth/g box
