Can anyone give some advise? I have refitted the kick start shaft on both bikes now, and yesterday i started the SE, everything was fine, BUT its obvious the kick start shaft Spring is not tight enough, when i reinstalled it i didnt put any tension on it so although it works fine and i can fold it back, it dose still move a bit, Can anyone tell me how its suposed to be wound up before itstalling and by how much. i know it was under load when i took it off but how much i couldnt tell as it shot accross the garage when i took it off anyway, if someone can help that would be great .......oh well engine case off again!
