 Topic: The kunk in the clutch
rzv500r
rzv500r » Wed Jul 21, 2004 4:28 pm
Hi Everyone,
I've got an mc28 with a dry clutch and am trying to diagnose a kunk noise when shifting gears, mostly noticable in lower gears like going from nuetral to first, or first to second but you can hear it in other gear changes as well.
At first I thought the clutch was just worn out, or possibly needed adjustment so I replaced it with a brand new genuine Honda clutch but that did not fix the problem.
The noise is from the trans kunking into gear like the clutch isn't engaging all the way, now I'm thinking maybe I have a bent shift fork or shaft or something. It almost sounds like your shifting without using the clutch at all.
Anyone else dealt with this before, or know what might be broken?
Thanks,
Eric
