 Topic: BR8ECM -- BR9ECM
BOSOZOKU
Re: spark plug heat range
BOSOZOKU » Sun Dec 18, 2005 9:12 am
motulman wrote:hello everyone....why would you run a different heat range plug on a water cooled engine? the cooling on these lil beauties has nothing to do with the air....educate me i can see being an issue on a aircooled bike if it was a 90 deg V but in this case i dont understand why it would even matter Very Happy
i was going to try and explain but cant be bothered read below and all will be revealed Wink
Also click the link and go to the '#2 HEAT RANGE' section there are some pretty pictures aswell.
Lots of other interesting information too well worth a look.
Heat range
The term spark plug heat range refers to the speed with which the plug can transfer heat from the combustion chamber to the engine head. Whether the plug is to be installed in a boat, lawnmower or racecar, it has been found the optimum combustion chamber temperature for gasoline engines is between 500ーC・50ーC. When it is within that range it is cool enough to avoid pre-ignition and plug tip overheating (which can cause engine damage), while still hot enough to burn off combustion deposits which cause fouling.
The spark plug can help maintain the optimum combustion chamber temperature. The primary method used to do this is by altering the internal length of the core nose, in addition, the alloy compositions in the electrodes can be changed. This means you may not be able to visually tell a difference between heat ranges. When a spark plug is referred to as a 田old plug・ it is one that transfers heat rapidly from the firing tip into the engine head, which keeps the firing tip cooler. A 塗ot plug・has a much slower rate of heat transfer, which keeps the firing tip hotter.
An unaltered engine will run within the optimum operating range straight from the manufacturer, but if you make modifications such as a turbo, supercharger, increase compression, timing changes, use of alternate racing fuels, or sustained use of nitrous oxide, these can alter the plug tip temperature and may necessitate a colder plug. A rule of thumb is, one heat range colder per modification or one heat range colder for every 75・00hp you increase. In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70ーC to 100ーC from the combustion chamber.
The heat range numbers used by spark plug manufacturers are not universal, by that we mean, a 10 heat range in Champion is not the same as a 10 heat range in NGK nor the same in Autolite. Some manufacturers numbering systems are opposite the other, for domestic manufacturers (Champion, Autolite, Splitfire), the higher the number, the hotter the plug. For Japanese manufacturers (NGK, Denso), the higher the number, the colder the plug.
Do not make spark plug changes at the same time as another engine modification such as injection, carburetion or timing changes as in the event of poor results, it can lead to misleading and inaccurate conclusions (an exception would be when the alternate plugs came as part of a single precalibrated upgrade kit). When making spark plug heat range changes, it is better to err on the side of too cold a plug. The worst thing that can happen from too cold a plug is a fouled spark plug, too hot a spark plug can cause severe engine damage
http://www.ngk.com/search_char.asp?seenWarning=1&manufacturerID=1
All info is on the NGK website Very Happy
MC21R Repsol replica
SC36 'Fire storm'
RG250 MK3 GAMMA 'WALTER WOLF'
DR350SEV winter hack
