Hi all,
I`ve wired up my HRC box & it starts & runs fine.
Went through the motions of testing everything works & found it would stay running with the side stand still down when put into gear.
I`m not too fussed but I`m gonna` be taking it for an M.O.T. test & think it might get picked up on.
I checked all the wiring connections & continuity tested the switch & associated wiring, all seems ok. The side stand light comes on when it`s down also.
Just wondering if someone`s come across this before? Is it normal?
Thanks in advance
Roy.
