 Topic: brembe radial master cylinder
Luke F
Luke F » Thu Jan 26, 2006 8:12 am
Is this for a race motard or street?
You can start wityh a NSR master but its a bit stiff and woodern, also graby get ready for fore arm pump, i use one for a while, did the job.
I use a 13mm brembo off a Ducati with a Gp mono block caliper , works fine, but it can get a bit weak on realy tight stop start tracks, constant fluid changes. came from QTM Brembo in states for 80 odd dollars plus postage!! and its what a lot of AMA riders use.
For the real deal get the made for the job 16x16 master from Brembo, perfect but when i was shopping for them for a mate I could only find one all others on back order!!
the 16x18 is what most go for cause its cheaper, does the job
Farting is funny
