 Topic: thermostat replacement help
Wrench.
Wrench. » Sat Apr 29, 2006 3:34 pm
- remove all your lower cowl.
- put a drain pan under your lower head hose connection
- pull the lower head hose connection and let all the coolant drain
- disconnect the hose from upper-left of radiator
- remove coolant overflow bottle (2 bolts, 1 nut, 2 small hoses)
- remove your seat and gas tank
- remove upper head connection hose
- disconnect 2 wires from thermostat housing
- slide the entire thermostat assembly with hoses attached out of the engine area.
Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
