hi guys, im new as you can see and would like to say what an outstanding and informative site you have, if i could ask afew questions about my project. i run a 250 sprint kart and im fitting up a mc21 with mc18 barrels and billet heads onto a crg chassis, what i need to know is the following.
how much of the wiring do i need to run for the igniton? can i dump the magneto or do i need that for the ignition? do i need to run the gear position sensor as well as the tps?
i only need the basics for a kart and ill also be running on alky as the class is open plus 38mm carbs.
any sudgestions would be great, cheer steve
