As some of you already know my NSR went pop at oulton park a few weeks back. At first the problem was thought to be mixture etc however turns out it was a spun ring! anyway, its been at BDK and i thought id share the bill i thought it wasnt that bad, he also rebuilt the other cylinder while it was off and removed the oil pump. the heads have been remachined to match as they had diffrent profiles. any way here you go!
WORK OR PARTS @ QTY PRICE
Replate 94.50 1 £94.50
Hone to cylinder 30.00 1 £30.00
Pistons 53.95 2 £107.90
Ring sets 19.95 2 £39.90
Head gaskets 9.85 2 £19.70
Base gaskets 3.86 2 £7.72
Small end brngs 6.00 2 £12.00
Gudgeon pins 6.32 2 £12.64
Weld repair to broken cylinder 25.00 1 £25.00
Labour to strip/fit barrels etc 90.00 1 £90.00
Dyno time 90.00 1 £90.00
Oil pump blanking plate 20.00 1 £20.00
Machine heads 30.00 2 £60.00
Powervalve shaft seal and clip 4.06 1 £4.06
£0.00
SUB TOTAL £613.42
VAT £107.35
TOTAL £720.77
Aty the very least itll give some non tech's what it cost to have someone do it for you!!
cant wait to run it up!
