 Topic: rc valve adjustment
Dave Ett » Mon Jul 03, 2006 4:12 pm
With it all plugged in and ignition off, manually position the valve to one of it's end stops. Switch on the ignition and it should move to it's start position. When idling, it cycles back and forth.
To set it up, either use the hole in the end bracket and a drill bit, or better still, remove the exhaust and feel the lower edge is flush with the manifold when fully retracted.
