MC28 carbs will fit the MC21, but the airbox from the 21 will not actually reach the carbs. You'll need an MC28 airbox. Also the throttle cables are different, as is the oil pump cable, but both can be modified if you're handy with the snips and solderless nipples.
Check jetting, check jetting and check jetting again.
