A good plan is to run all thick steel plates of the correct total quantity.
No damper rubbers makes for a good noise at the traffic lights.
A knackered clutch hub makes more noise as the plates jangle back and forth, but can also make the clutch judder if it gets too bad, which can make a smooth quick getaway from the lights a bit of a struggle, and instantly destroys any cred you gained from having a noisy clutch.
