ah right thats good to know. so no spaces needed then around the headstock? so do you also use vfr yokes too.
if the brackets would work i would prefer to use them really as all i want to do is fit some brembos/sp1 calipers to the NSR. I mean will the brackets make the calipers fit ok on the smaller nsr discs too?
But i will keep that in mind.
If i were to say fit some zxr400 forks, would i need to get a spacer made up for the headstock etc..?
thanks for the info i will keep that in mind. But ive always said to myself that if i changed the forks it would be for some USD's.
