I am also experienced in gaseous and hydraulic aircraft systems. The nitrogen I use is 99.9% pure and dry.
It's actually around 78% in the atmosphere but it's the 21% of oxygen that is the problem and if you live in an area like the UK a lot of moisture.
I personally don't want to put 'air' in my £500 shock absorber and I don't think it's fair to advise others to do this either without explaining the advantages & disadvangtages. The only advantage being short term cost.
I wasn't trying to correct you but just sought to clarify for others that air is not what is normally used.
http://www.rgv250.co.uk
http://www.thetuningworks.com
