 Topic: Tapping RC Valve.
Matt@TYGA » Tue Oct 24, 2006 1:41 am
I've had this a few times when the shaft has worn and has a bit of slop. It's worth replacing the shaft 'cos valves that move about are potentially disaterous. The minor problem is that the exhaust timing will be constantly wriggling about as the valve position fluctuates. The major problem is when the play gets enough to catch a ring and BOOM!!!
