 Topic: Hi Capacity/Heavy duty/Competition radiators
Matt@TYGA » Mon Nov 06, 2006 2:10 am
Sticking a fan on the NSR is not a too tricky job. Just takes a bit of wiring etc.
I also fitted a fan to another 300 here in Thailand but this time on a 21.
Another way for the 21 would be to wire it into the GPS, so that the fan would be auto in say neutral, 1st & 2nd, and then switch off when you went into 3rd. Need to wire it up through a couple of relays though so that we could isolate the neutral wire to stop the neutral light coming on in the 1st & 2nd.
The 18 and 28 would have to be wired into the neutral wire on the GPS and then have a hard earth switch if you wanted it on any other time.
Maybe I should wire one into Paul's MC21 while he's not looking so that I can get an idea of how much it'll cost.
The fan I'd use isn't exactly huge, but it's better than nothing, and it's about as big as you can fit comfortably on the NSR rad.
As with the fibre under seat cover, let's see what sort of serious interest there is.
Oh Mike, give me a shout when you're in Pattaya and I'll try and fit this RS rad that I have here with me. I'm guessing that you'll have some excess cash that'd only be wasted on Singha beer and Vitamin V if I don't step in Wink
