hello again
Thanks for the advice, i'm going to have a look at replacing the base gasket
Started to take it apart, and noticed that the nut on the leaking bolt has a groved bottom. Could that have cause the problem? I think i must have put the wrong one on when doing it up
the one on the left is the one that was on the leaking bolt, the one on the right is what was on the other 3 bolts
