 Topic: 2stroke oil lamp indication
StephenRC45 » Wed Dec 06, 2006 1:05 pm
The oil light should light up when the ignition key is first turned on with the kill switch in the run position. It will then go out after a few seconds. If it doesn't light up then either the bulb has gone or you have a short in the wiring.
