 Topic: Q: must cylinder/exhaust connection be totally airtight ?
Steve C
Steve C » Sun Jan 14, 2007 5:04 pm
Air tight is what you want. The gasket that goes between the flange and cylinder I put a little high temp silicon on. Also put a good bead around the flange where the pipe slides on. It just helps to keep the black guew from seeping out over time.
