 Topic: G'day new member.
studricho
studricho » Wed Jan 17, 2007 8:40 am
Matt@TYGA wrote:The idle adjuster is a big yellow knob thingy that you screw in to raise the idle and out to lower.
The air screw (mixture screw) is a brass screw at the rear of the carb, next to the airbox mount rubber. Screw this in to richen the mixture and out to lean off. The standard Honda setting is 2 turns out from fully seated.
Thanks again Matt. I did know what the yellow knob did by the way.
Unforgivness is the poison we drink hoping the other person will die!
