I dont know much so enlighten me but why do you need to use the Honda PGM when the motor will be a Yamaha motor with NSR barrels, the crank timing will be different?? Dont you need to use the Yamaha ignition system but even than I cant see that will work as the port timing will be different for the NSR barrels so surly you need to build a one off ingition/PGM system _________________ Harley Davidson is the worlds most efficient way to turn petrol into noise without the harmful side effect of horsepower.
