 Topic: coils and trouble
Jim
Jim » Tue Nov 16, 2004 3:41 am
The way this has been going, it might well be cheaper to fly both of you out here in the off-season! I can source beer and John apparently can source the sleazy women - classy women may take a bit more research...being married and waaay out of the loop, I would have to rely on others for that too. Smile
Andy, the wiring diagram seems to indicate it is a continuous wire from the PGM to coils (no connectors). It disappears into the wiring loom and then isn't seen again until the other (coil) end. No obvious cracked insulation where i can see the wire anyway. Consensus seems to be I won't damage the bike if I limp it home on one cylinder, so I'll probably go ahead and see what happens with the new female coil connectors - probably just won't venture too far....will be watching the airfares too.
Thanks for the help.
-Jim
-Jim
'93 MC21
