 Topic: Limited rpm in 3rd gear onwards
SLF-951
SLF-951 » Mon Mar 12, 2007 11:28 pm
quote:
Originally posted by StephenRC45:
I would check the fuel tap for flow and fuel tap filter first.
After that strip and clean the carbs.
If the bike was running well with the current setting there is no reason why it shouldn't again.
Quite often a bike lacking fule will rev out in the first couple of gears only to give up once the fuel demand is greater.
Sounds right on if the bike is running fine other that at top revs and load....
I've seen once the fuel tank vent get cloged on a dirt bike cause the same type symptoms. Same lack of fuel at top end....
MC21
04 NSR50R
93 CBR F2
98 CBR F3 track bike
95 VFR750
89 FL400R Pilot
90 FZR 4/600
