 Topic: New noises.
Matt@TYGA » Fri Mar 23, 2007 1:43 am
Could be the bearing, but more than likely the front sprocket.
Take a look to see if the teeth are worn or bent over.
If it's the bearing then you need to pull the gearbox out. Don't need to drop the motor.
